HarryN
Hi, I am working on building a DC breaker panel - similar to the ones used on boats.
It will be typically be for controlling ( on / off / safety ) of 24 volt, LiFe batteries in the 100 - 200 amp-hr range.
I have the basics worked out, more or less just some off the shelf DC breakers.
It would be nice if this could also activate an led indicator light for when that breaker is activated. So for instance turn on a pump - an indicator light would turn on.
Here is an example of some.
It would be nice if it could work on 12 or 24 volt, but that is not a "must".
Any led in the 3 - 5 mm range is fine.
Thanks
Harry
Thanks
Harry
