[Preorder] Copper Lumintop FW21 PRO 3* XHP50.2 3V 10000lm 21700 EDC Flashlight
freeme
More Details: https://www.1thedeals.com/product/l...p50-2-3v-10000lm-21700-edc-flashlight-copper/
[FONT=&quot]
Specifications:[/FONT]
  • [*=left]Emitter: Three LEDs on a copper DTP MCPCB e.g.
    [*=left]Cree XHP50.2 3V LED
    [*=left]Optic: Aluminum Orange Peel reflector
    [*=left]Lens: Glass with anti-reflective coating
    [*=left]Flux: ~10,000 lm
    [*=left]Intensity: ~26055 cd ANSI throw ~325 m
    [*=left]Firmware: The FW21 pro uses free software called Andúril,
    distributed under the terms of the GPL v3.
    [*=left]User interfaces: [1] By default the FW21 pro is set to use SMOOTH RAMPING.
    Instant access to TURBO mode is also provided.
    [2] A more conventional STEPPED RAMPING UI is available if you
    like discrete modes level. You can choose how many steps you want.
    [3] MOMENTARY mode is useful for signaling purposes or rapidly/briefly
    lighting up targets. To exit this mode, physically disconnect power
    [4] MUGGLE mode uses a reduced output.
    [5] It has an electronic LOCKOUT for safety, but acts also as momentary
    low light.Other functions: Battery check, sunset, beacon,
    tactical strobe, party strobe, bike flasher, candlelight, lightning storm
    [*=left]Battery: One flat-top or button-top 21700 cell. An unprotected cell is recommended.
    [*=left]Max. length 70.5 mm. Cell is not included.
    [*=left]Driver: FET+7+1 driver. Low parasitic drain while OFF
    [*=left]Body: Aluminum with hard-coat anodizing
