I didn't know if it would be good forum etiquette to resurrect such an old thread, so I opted to reference the old thread and ask this question in a new post. REF: http://www.candlepowerforums.com/vb/showthread.php?154756-Maha-MH-C9000-Wizard-One-Charger/page2
If this is the case, then wouldn't it also be detrimental to AAA cells to do a "Break-In" cycle on them?
For example, If you're charging an 800 mAH AAA cell, the charge current during the Break-In cycle will be 80mA. At this current, the cell will be "fully charged" in approximately 10-11 hours (90% duty cycle of the C9000). Since the C9000's Break-In charge cycle runs for 16 hours, that would mean an addition 5-6 hours of charging at 80mA.
If, as stated above, an extra two hours of "top off" charging at 100mA would be detrimental to the cell, wouldn't an extra 80mA for six hours also be?
I'm asking because I'm about to do a Break-In cycle for several sets of AAAs, and wanted to know if there is anything to be mindful of during the process that might potentially damage the cells.
Hello Hoggy,
Yes there is a 2 hour top off after the charger shows done. The top off charge rate is 100 mA.
With AAA cells, it is not a problem if you charge at higher charge rates. For example, if you have 800 mAh cells, you should charge in the 500 - 800 mA range. If you do this, the charger will terminate on high voltage (1.47 volts) and utilize the top off charge to complete the charging process.
If you charge AAA cells at 200 mA, you could run into some problems with overcharge from the top off charge. Of course this would depend on the capacity of the cells you are charging.
Tom
