Locoboy5150
- Joined
- Nov 3, 2009
- Messages
- 1,102
What brand contact cleaner did you use?
Thanks for the info!
You're welcome. :)
I used CRC Electrical Parts Cleaner, part number 02180:
http://www.crcindustries.com/ei/content/prod_detail.aspx?S=Y&PN=02180
I bought it at least ten years ago from Fry's Electronics, a local electronics dealer here in the Bay Area. If you're going to buy contact cleaner from a local vendor, some places call it "TV tuner cleaner" since it was commonly used to clean TV channel change controls back when they were mechanical switches.
You might want to buy a big can of the stuff because it can be used to clean just about any electrical connector or switch in your house and car. There are generally two kinds available, one with switch lubricant and one without. The one that I used on my TK40's switch and linked above does not have lubricant. I've used both extensively and the kind with lubricant does attract dust over time but that is its only downside.
Also note that electrical contact cleaners will degrade some plastics immediately on contact. I sprayed the CRC brand cleaner in the switch of a fan once and it just disintegrated the switch's black plastic housing instantly on contact. It made the plastic brittle and it just cracked and fell apart and almost turned to dust. So before you spray it on something, check around the switch to make sure that there is no plastic nearby that could be harmed from over spray. It did not harm any of the plastic parts on my TK40's switch though and I seriously doused the whole thing with the contact cleaner.
Also, be careful when spraying the cleaner on a small part like your TK40's switch. The spray comes out very quickly and at close point blank range like that it can bounce back and bast you in your face and eyes. I wear glasses so I've never gotten back blasted in my eyes but it doesn't feel good to get smacked in the face with the stuff. Ask me how I know! :D
