www.imalentstore.com
[h=1]IMALENT DX80[/h]
IMALENT DX80 is a rechargeable LED flashlight. It is a 32000 lumens flashlight, 8 CREE XHP70.2 LED super bright flashlights, rechargeable searchlights, professional waterproof searchlights, which can maximize brightness and normal operation in various environments. Easy to use, search and rescue outdoors, enabling you to effectively plan and reduce the risk of dimness in darkness and storms.
IMALENT DX80 has high brightness and small size; with an output of up to 32,000 lumens, this flashlight illuminates everything
Six output levels + strobe (turbo mode: 32000 lumens, normal mode: 13000LUMENS / 5000LUMENS / 1500LUMENS / 500LUMENS /120LUMENS); DX80 can meet your expectations regardless of the terrain and environment.
OLED display, showing lumen output, voltage, charging status and overheating warning; the built-in OLED display will ensure that you will not miss any beats, and its status warning, mode output and other functions will ensure that you are always in full control.
Instant boost mode, press the pressure switch at any time; use Instant Turbo mode to light up the darkness! Reach the maximum output on the DX80 immediately, and with just one touch of a button, you can be sure you always have what you need.
Easy-to-operate tactical pressure switch; similar to Instant Turbo mode, our easy-to-use pressure switch ensures that you are always in control. A comfortable click will also ensure that you always get the feedback you need from a high-performance flashlight.
Rechargeable battery pack, including eight original IMALENT 18650 rechargeable batteries; our Imalent batteries are like flashlights and are the best in the industry. We want to know that our customers are safe, so please always use our Imalent battery and flashlight, this is the best!
Product Features
Product Features
[*=left]With 8 US CREE XHP70 second-generation LEDs, it has a lifetime of 50,000 hours and a maximum output of 32,000 lumens.
[*=left]The versatile OLED display shows various parameters and settings.
[*=left]The built-in battery pack includes eight 3000mAh high-discharge 18650 lithium-ion batteries.
[*=left]High efficiency constant current circuit maintains constant brightness
[*=left]Anti-reverse battery protection
[*=left]Built-in thermal control module automatically adjusts brightness output
[*=left]Combined with toughened ultra-transparent mineral and anti-reflective coating glass
[*=left]Aluminum OP reflector
[*=left]Aviation grade aluminum alloy body, wear-resistant type III hard anodized surface treatment
[*=left]IPX-8 standard waterproof (2m submersible)
[*=left]1.5 meters impact resistance
[*=left]Tailstock function
[*=left]Dimensions: 213 mm (length) * 92 mm (head diameter) * 50 mm (body diameter)
[*=left]Net weight (including battery): 1204 grams
