Proper D30 Howitzer spotlight battery
StuGatz
Hello,
I have an older D30 Howitzer spot light that is able to use two styles of battery, either three stacked in the center or three seperate stacks around the sides of the battery compartment. Please let me now which battery to order, either the 18350, 26650, or the 18650?
Thank you in advance,
Stuart
chillinn
Mobjack Bay
XTAR D30 Howitzer 3xMC-E diving flashlight can use either 6x 18650 or 2x 32650. Though the linked page also lists a 4x 18650 configuration, I can't confirm that anywhere. But it doesn't use 26650 or 18350 cells. You may be able to use 26650 cells with sleeves to widen the diameter to 32mm. I tried finding information on it using archive.org, but snapshots of XTAR's sites only go back to 2016, and I think that light was discontinued several years before.
