Billson
Payment sent for 1 x PXR-19-DE.
$18 + 6 intl shipping
reiko19480221 said:C.C. PayPal sent.
(sent twice for [1] original order and [2]balance for additional order and C.C. handling fee)
CPF ID = reiko19480221
1pc of PXR-19-Ce-Cu (MagC Copper version) = $28
2pcs of PXR-19-De-Cu (MagD Copper version) = $56
8pcs of Cree XRE LED (P4 bin) = $80
International shipping = $6
Total = $170
handling added = $176.8
Thank you!
Regards,
Reiko Kashiwagi
modamag said:Brian,
I knew you would like the low stain version. The center tap is for those who have a lathe and wish to make a PR socket adapter for it :hint-hint:
As for the reflectors, they should be available now. I'll check on these B4 I head out of town.
Merry Xmas,
Jonathan
DonShock said:PR socket is one that is designed to hold the PR type bulbs like in a stock Maglight. These are the bulbs with the flat sides and the flat rim around the top that is used to hold the bulb in place. On the Mags, a screw on bulb retainer used the flat rim to hold the bulb to the base. Other lights use a friction fit socket to hold the bulb in or just hold the bulb up against the rear of the reflector.
If you can rig a PR socket adapter (basically just a round post with the positive contact in the center and the negative contact at the outside edge) to these heatsinks it makes it a simple drop-in replacement on the Mags. If you don't use a PR based adapter, you need to tie wires into the switch itself.
Mirage_Man said:Also if the XR19 reflectors are available it's not showing anywhere on the Shoppe's site. How does one go about ordering them if they are not visible?
MM
modamag said:This sale will only be valid from up to 12/30.
