Bullyson
I've been wanting to buy one of these lights but first wanted to ask if anyone knows if it has the P60 drop in or the head assembly like the newer KX4 head used on the G2? I've seen some that are incandescent and some LEDs.
If you want to stay with incan...http://www.lighthound.com/Lumens-Fa...eFire-E-Series-IMR-Batteries-ONLY_p_2837.html And don't forget the IMR batteries.
One of the others can prob answer this better, but I know this IMR batteries can handle heavy amp loads better than other battery types.What does the IMR battery get you? Runtime? I have never used IMR.
The older E2E have a removable bulb. They have a special e series bulb that is not at all similar to the P60. The newer E2 have a one piece head/ Light Engine. You can get aftermarket LED dropins for the Incan E2 heads.
You will need a high discharge battery with that bulb. The AW IMR batteries are great for high amp draw devices.
IMR are without protection so you have to use it carefully or not?
