Question for Brand New NIMH Accupower Evolution LSD's
powerup93
My question is, is it normal for the very first few uses and charges to be lower runtime (capacity?)...and that it takes a few cycles of uses/charges to have their rated or normal runtimes/capacities?
I have 4 C-cells running a P7, and it seems like the TOTAL runtime (almost always on high) is like about 2 hours. Is that expected?
How are the cells powering the P7? Driver? Direct-driven?!?! Any idea how much current is being drawn from the cells?
AccuEvolution C's are 4500mAh, so 4x is a nominal 21.6Wh. At full power, a P7 draws at least 10W, so two hours sounds about right.
I use 3x AccuEvolution C's to direct-drive a P7, and I love 'em. Great cells!
Well based on your experience, then I guessssss mine are doign fine and are correct.
I'm running shiningbeam's 3-mode driver (8xamc7135's)
At 100% efficiency, you're looking at ( 21.6Wh / 3.7V ) / 2.5A = 2.33h.
The driver's not 100% efficient, and Vf of the emitter is more of a variable (increasing as the emitter warms up), so ~2 hours sounds reasonable.
