Quick question /Arc resistor size
Noxiousbt
Seattle, WA. USA
My meter does not read precise enough to tell exact resistor size on a LS rev2 board. Soldered on the board, my meter reads .4 ohms, but that didn't sound right. Could someone kindly let me know for sure? I would appreciate it.
Thanks,
Brandon
Uh... I would hazard a guess @ 0.15 ohms, but that's for current revision boards, not sure if that is actually the "rev2".
Should be .15 ohms for .333mA
To check you can place both leads at one end of the resistor and take a measurement - this will give you the resistance of your meter leads touching the pad. Then measure across the resistor. Now subtract the first measurement from the second and you should come up close to .15 ohms.
Thank you both for your help I am greatfull. I forgot little stuff like that after a few year of not being in electronics.
