Diving Gecko
- Joined
- Feb 17, 2013
- Messages
- 24
So, I am having a hard time finding Cute-3 optics for XML out here in China, where I am based.
But I may have found some for XP but after looking at spec sheets for both Cute-3s for XM and XP, I am wondering whether they are the same?
All the physical dimensions are the same.
Even the hole for the emitter (4.4mm). Only the beam angles change as in the eg. the narrow Cute (C10754_CUTE-3-SS ) is more narrow in the XP version but that could be explained by the emitter being inherently more narrow.
Does any of you happen to know if they are actually the same as long as the first part of the part number is the same...?
One way to check it is if one of you have a Cute-3 for XM-L and a sliding caliper around and the time on hand and inclination to just take the measurement where the emitter goes into the lens?
I would have thought that a designated Cute for XM-L would be bigger than 4.4mm as the emitter itself is 5x5mm.
