R2 drop-in question?
cir2kuk
Solarforce® 300 Lumens Cree 7090 XR-E LED R2 with excellent bulb reflector, maximum the CREE led output performance
The new version bulb output are more concentrate and focus, the light are bright & white
Strict quality control by solarforce, quality is ensured.
Provide 300 Lumens output for your flashlight
40% power saving when compare to same output level Xenon & Luxeon bulb
6V provided 250 lumens output
9V provide 300 lumens output
Compatible for the flashlight below:
superfire® 6P, 9P
Ultrafire® 6P, 9P
Bulb life hours: Over 50,000 hours
4.5v to 9v Bulb
Powered by: CR123A 3.7 x 2 or CR123A 3.0 x 3
Just wondering why you need 9volts to get 300 lumens?
Probably because it isn't fully regulated ?
You also should be aware that Solarforce exaggerate their outputs so you won't be getting anything like 300 Lumens anyway.
I already have the R2 drop-in and tested it at 4.5v and 6v, amazing difference in brightest at 6v.
Would i see a big difference at 9v over 6v and would it be safe?
