Ra Clicky operation question
ThumperACC
New England, USA
Hi All,
I've been reading the users manual for the Ra Clicky EDC tactical and I'd like clarification on the tailswitch operation.
The manual states..."
The term “​
press-hold-release” indicates that the button should be
held down for an extended period – longer than 1/3 of a second – to
allow your flashlight to tell the difference between a click and a presshold-
release."
If I define a click as "Press switch, past momentary on, until click is heard and then release the switch at which point a second click is heard. making sure that the time between click sounds is less than 1/3 of a second".
Then I could interpret the manual's description of "press-hold-release" in one of 2 ways.
1 - "Press switch, past momentary on, until click is heard. Pause in this switch-pressed position for at least 1/3 of a second and then release the switch at which point a second click is heard."
2 - "Press switch to momentary on position (no click heard) and hold this switch-pressed position for at least 1/3 of a second and then release switch (again no click heard)"
Which of the above 2 descriptions is correct?
Also, does the tailswitch have a momentary position before the click?
Thanks,
ThumperACC
Momentary in a Clicky is different from, say, an L4 in that while the L4 momentary is "press lightly for momentary -> press harder, hear a click," the Clicky momentary is "press and hold for greater than a third of a second, then let go to release momentary" and constant is a quick click (less than a third of a second).
In other words, there is no separate momentary on the switch. Momentary is defined solely by the length of time you press the button to turn the Clicky on (greater than a third of a second).
Hope this helps!
Hope this helps!
Antikythera, that helps immensely. :) Thank you very much.
ThumperACC
