RayOVac 4.0 vs Eneloops [data results]
InHisName
Warminster, PA
I have finished break-in testing with the 4 Ray-O-Vac4.0 AAA and the first 4 Duraloop AAs. I also measured the internal resistance as setup by the PLD IRM-004. It measures internal resistance with a 1KHz 1 [FONT=DejaVu Sans, sans-serif]Ω[/FONT] load, steady 1 [FONT=DejaVu Sans, sans-serif]Ω load, and 0.5 [/FONT][FONT=DejaVu Sans, sans-serif]Ω load.
I just received two Tenergy D 9000 MAH cells from fellow CPF'er, he wrote the capactiy on the batt. I havn't had time to test those my self yet. I added the internal resistance tests here.
[/FONT]
Code:
Ledgend:
MAH     1 Khz 1 Ω load 1 Ω Load 0.5 Ω load
Break-in  Cell Voltage      Volts     Volts
Orig              mΩ            mΩ         mΩ
Ray-O-Vac4.0 AAA
760              1.43           1.12        0.97
533                92            114         345
772              1.40           1.16        1.02
575               101            106         279
794              1.40           1.11        0.94
578               143            131        395
811              1.43            1.07       0.87
598                32             232        548
Duraloops AA
2083            1.40            1.12       0.94
1563             143             115        388
2082            1.44            1.18       1.01
1469              59               56        332
2081            1.44            1.12       1.04
1507              43               33        293
2062             1.44            1.21      1.07
1511              245             255       259
Tenergy D 9,000 MAH
7718            1.43           1.13        0.95
                 177            142         398
7756            1.44           1.16        1.01
                 77             76         324
[FONT=DejaVu Sans, sans-serif]All the new Ray-O-Vacs seem pretty similar to the Duraloops. Not to mention that ROVs are AAA and the Duraloops are AA. So far most cells of AA, AAA, and D size are pretty similar in the internal resistance at 2 amps (0.5[/FONT][FONT=DejaVu Sans, sans-serif] Ω load). The designer/builder of the IRM-004 says the number don't really mean much until changes are compared over time and other comparative differences. I have noticed that when the 0.5 ohm load values climb up over 900milli-ohms then my C9000 starts giving me the HIGH signal. So ...... under 500 is good, over 900 not very good any more.
[/FONT]
