The E1L and E2L are LED lights with no bulb to burn out, so the question is a little confusing (suggesting that maybe you are talking about the E1E and E2E)... anyways.. I don't know much about the new E series LED setups, but I seem to recall reading that some folks were running the E1L on a RCR123 without problems, but I don't want to say for sure, you could probably get away with some 3.0V LiFeP04 cells if you want rechargability that won't change the input voltage too much from using regular primary cells. however they will only deliver about 1/3rd the runtime of primary cells.
For your 9P, Z2, and 6P simply telling us which emitter you have does nothing to help recommend a battery configuration, however, IF the drop-in module you have in the 9P is the same as the ones in the 6P and Z2, AND you have run the 9P with the module on 3xCR123 primary cells, then you can safely run the 6P and Z2 on a pair of RCR123 3.7V cells with no problem. The 9P would be much better off with pair of 17500s (2 cells that fit the space of 3 CR123 size cells). I don't think I would recommend running the 9P on 3xRCR123s as the amount of voltage that would have to be bucked would be pretty high, which may cause the board to overheat depending on what it is designed to handle.
