My short answer is probably not. But, perhaps someone else has found one?
I guess the closest thing that I have ever seen was a flashlight that I purchased at a "big box" store here in Japan. It was not very bright, but it was a decent functional flashlight. And, it had a "large" (about 1.5" x 4.0"?) solar panel. But, in addition, it also had a "dynamo" that worked on a "pull string." (Like the pull rope on a lawn mower.) It seemed like a reasonably practical light, and I purchased several. But, I think I have given them all away, so I cannot post any pictures. The reason I felt that this light was "reasonably practical" was that the "pull string" mechanism would allow you to easily generate some serous RPM. (Regular hand cranking gets old in a hurry.) Even so, I think it took several minutes of vigorous "pulling" to generate a full charge. And, while quite strong, the nylon string would likely break in time, if you used it very often. So, it was strictly a "survival" light, I think.
