Rechargeable AA's, MN01 or R30?
oldgrandpajack
Rechargeable AA\'s, MN01 or R30?
I'm considering trying the UBH with NIMH batteries and either the MN01 or R30 Lamp Assemblies. The MN01 would be a lot easier but I suspect that the R30 would perform better.
Question #1: Has anyone compared the output of both the MN01 and the R30?
Question #2: Will the MN01 work with rechargeable batteries? Concerned about possible shortened life of LA.
Question #3: I assume that the R30 is compatible with rechargeables because of the "R". Am I right about that?
Question #4: Is the KL1 as good as either of these, AT A DISTANCE? Wouldn't be any point in trying this if the KL1 matches or exceeds their performance, at a distance.
Question #5: In a pinch, would either of these bulbs work with Alkalines, like the KL1?
The only parts I don't have, at the moment, are the MN01 and KL1. I would appreciate any and all comments and suggestions.
Thank you,
oldgrandpajack
Re: Rechargeable AA\'s, MN01 or R30?
The UBH/II run perfectly fine with the MN01 and Alkalines or NiMHs... I'm not sure about the R30, as I don't have it to test out...
The KL1 provides as much lumens as the MN01, if not more so. And in a UBH, I prefer to run the KL1 as opposed to the MN01, unless you want a little more throw, in which case the MNO1 will outthrow the KL1 (due to its reflector)...
I turned my MN01 into a flashbulb with a pair of Energizer L91 lithium AA's.
The 1.1 A R30 is much brighter to my eyes than the 0.7 A MN01. It will run with NiMH's but not well with alkalines. While I still had my R30's, I sometimes ran them in a D3 body with a pair of 2700 mAh Sanyo A NiMHs for a 2 1/2 hour run time.
I see no reason to use an MN01 if you have a KL1. An R30 is brighter. On the other hand, the R30 is still wimpy enough that I traded both of the R30's that came with my 3P's for an equally old pair of seldom used R60's.
The final straw for trading the R30's was when I discovered that a PT20 with a pair of lithium AA's drove a cheap and readily available Rayovac 2.0 V 1.2 A KPR bulb with a beam that was almost identical to the R30 beam.
