Howdy - Looking for a rechargeable duty light that will spend a majority of its time in a parked vehicle on shore power. I've used the checklist as advised, any questions or recommendations please let me know. Thanks
I will be mail-ordering or buying online, so this doesn't matter.
2) Budget: An easy question, but you may change your mind after answering the rest! :-)
Less than $300.
3) Format:
I want a flashlight.
4) Flashlight-specific format/size:
duty size, Holster carry.
5) Emitter/Light source:
LED
6) Manufacturer:
I want to buy a light from a traditional mass producing manufacturer that is ready to go out of the box.
7) What battery type do you want to use?
I intend to use rechargeable nickel chemistry (NiCad, NiMH, NiZn)
I intend to use rechargeable lithium (li-ion) chemistry. Feel free to specify a size if you know which size you want (14500, RCR123/16340, 17500, 17670, 18650, etc.)
8) How much genuine out the front (OTF) light do you want/need? Sometimes you can have too much light (trying to read up close up with a 100 lumen light is impossible).
I want to illuminate an entire field, the neighbor's front yard several houses down, impress my friends and neighbors, etc. (300-700 lumens).
9) Throw vs. Flood: At what distance will you be most likely to use this light? Select all that apply.
50-150 yards/meters
10) Runtime: Not over-inflated manufacturer runtime claims, but usable brightness measured from first activation to 50% with new batteries (Measured on maximum output).
3 hours +
11) Durability/Usage: Generally the old phrase “you get what you pay for” is very accurate for flashlights.
Critical (Police, Fire, Search & Rescue, Caving, Survival).
12) Switch Type and location (choose all that apply):
I want a body mounted switch (near the head, like on a Maglite).
I want a tail mounted switch (found on the majority of today’s high end lights).
Other, please specify_lock out feature to prevent accidental activation would be handy.
I want 2 light levels. (Brighter/short runtime and Dimmer/long runtime.)
14)Material/Finish/Coating
I don’t care.
Other, please specify some water proof required ≥ 3 foot depth okay.
Less than $300.
3) Format:
LED
6) Manufacturer:
50-150 yards/meters
3 hours +
I don’t care.
