Thanks to all who have responded. There have been a dizzying array of choices and I have a few more questions. Although over my budget the dereelight javelin seems promising. Is the javelin adequately waterproof? The XR-E led was reccomended over the XP-G but I cant seem to locate the XR-E version. Would the XP-G version suffice? What is the P-60 head on the javelin and how might this affect my purchasing decision? Will this light take lithium batteries? Thanks again!
The Javelin is as waterproof as any other light. P60 is a standard for 26mm lamps/lamp assemblies that you can easily interchange as new tech becomes available. You can buy aftermarket "P60 dropins" which are complete reflector-lamp assemblies that will fit into the Javelin provided the voltage of the dropin is correct.
I have the DBS body, but a Javelin module. This allows me to use the larger reflector of the DBS with 2-3xAAs.
You can also buy other bodies to screw on the head, but again you have to match the batteries to the voltage of the dropin.
Lithium? If by that you mean those Energizer Lithiums, then yes. 2x14500s (AA sized Li-Ions) then no, youll need a AA sized spacer. If you want Li-ion your better off with Javelin head and C2H body to use a single RCR123. Point of the Javelin is to use AAs to get throw previously reserved for Li-Ion based lights. Using Li-Ion makes no sense when there are dedicated solutions available like the CL1H which still uses the Javelin sized reflector.
Since the Javelin is designed with throw in mind it probably won't sacrifice much for output. The XPG will give you more overall output sacrificing 2,000-3,000 lux in the process. It still has the most throw of any AA light I know of.
The XRE is available (pictured above, i think there were some XPG beamshots somewhere...) but you need to email flashlightconnection to see if Jay still has some. The 3-mode XRE is available from dereelight directly.
