I will be mail-ordering or buying online, so this doesn't matter.
2) Budget: An easy question, but you may change your mind after answering the rest! :-)
Less than $250.
BUT
I’m flexible, tell me what you gotJ.
3) Format:
I want a Weaponlight.
4) Flashlight-specific format/size:
2xAA so 6-7 inches. The lighter the better.
5) Emitter/Light source:
LED (known for efficiency, longevity, and compactness)
6) Manufacturer:
Either, as long as it is reliable
I want to buy a light from a traditional mass producing manufacturer that is ready to go out of the box.
I would consider getting a light that is pieced together (for example a “host” or flashlight body from one manufacturer, and a “drop-in” emitter from another source). Under the right circumstances, this path can provide more options to the consumer to meet specific needs, and can often be easily upgradeable as technology improves.
7) What battery type do you want to use?
I intend to use alkaline batteries (AA) as an emergency backup
I intend to use lithium primary batteries (Energizer Advanced/Ultimate Lithium AA) as the main source of power
8) How much genuine out the front (OTF) light do you want/need? Sometimes you can have too much light (trying to read up close up with a 100 lumen light is impossible).
I want to illuminate my entire backyard or a campsite (150-300 lumens).
9) Throw vs. Flood: At what distance will you be most likely to use this light? Select all that apply.
Less than 1 yard/meter (reading, other close work)
Less than 5 yards/meters (looking for something inside a dark shed/garage/basement)
5-20 yards/meters (check out a noise in the backyard)
30-50 yards/meters (I have a big backyard)
50-150 yards/meters (I live in a very rural area/farm with wide open spaces)
To be honest I have no business shooting at something farther than 100 yards away from me.
10) Runtime: Not over-inflated manufacturer runtime claims, but usable brightness measured from first activation to 50% with new batteries (Measured on maximum output).
60-90 minutes seems like a decent balance between brightness and runtime
11) Durability/Usage: Generally the old phrase “you get what you pay for” is very accurate for flashlights.
Critical (Police, Fire, Search & Rescue, Caving, Survival).
12) Switch Type and location (choose all that apply):
I want a forward clicky (Helpful for momentary activation and signaling).
A simple on-off with only one output level is fine for me.
I don’t know.
14)Material/Finish/Coating
I don’t care.
15) Special Needs/extras: Is there anything else you want or need that hasn't been mentioned? Select any below.
Must have a 1" or .8" diameter so that it can be mounted to an AR-15 (This is because almost all the lightmounts are made for the Surefire P or E series flashlights).
For logistical reasons (mainly just tired of buying CR123a's for two flashlights), I have decided to move my pistol light (X300) and AR-15 Weapon-light (6P LED) over to AA alternatives. For my pistol I plan on ordering an Insight WL1-AA. However for my AR-15 the weapon-light choices seem much narrower, as in there aren't really any dedicated purpose built weapon-lights.
An AR-15 is not exactly a harsh recoiling rifle so I'm not TO worried about the light becoming damaged. However from what I have read the recoil MIGHT cause a light with multiple settings + a clicky switch to alternate between the modes. Is this true or internet rumor?
Next up are the Chinese manufactured lights (Fenix, Eagletac, Olight, Quark, etc) reliable enough for a two way range? I trust Surefire with my life, cause guys who run into danger trust them with their lives. Would a Fenix or other Chinese light crap out in any sort of serious or prolonged use? Have they been around long enough to be tested?
Next up mounting the lights and run time. The Quark X Tactical looks interesting but only .8 hours of run-time on Lithium batteries seems very low to me. Right now the Eagletac P20A2 MkII looks like the best choice. 1.5 hours ~280 lumens, .8" diameter, but Eagletac seems fishy as hell to me. There website is poop, and their contact info is a joke. In addition there flashlights look nearly identical to many of Fenix's. I am suspicious that it is just some Chinese company rebranding Fenix or another manufacturers lights.
Less than $250.
BUT
3) Format:
6) Manufacturer:
I don’t know.
I don’t care.
