REDUCED 3X vinhnguyen54 Random Modded Lights
Status
Not open for further replies.
Skylumen
Some custom lights modded by me ;-)
SOLD $135 $145 $150 Modded Direct Drive Maelstrom S12. I did direct drive on the S12 before but the results was never satisfying as I could not get to the inside of the S12 guts. No matter what I did I just could could not remove the head of the flashlight from the body. Therefore, there are resistant here and there which cause the current draw to be no higher than 4.8A at start up. Yes the light could draw up to 6.5A+ when it’s hot but Hot Amps somehow doesn’t equal greater lumen. Anyhow, I finally figured out a method to disabled the head on the S12 from the body with no damages at all. I proceed to make a custom direct drive PCB board and run dual 26AWG Teflon wires to the LED in the shortest length possible. I also added more thermal paste than what the LED originally had for better heat sinking. The result is now 6.1A on orange IMR at cold start. The light is now noticeably brighter than before. Please beware that the LED in this S12 undergo a time consuming burning in process to acquire this amperage. Your S12 might not acquire this current flow with the exact same mod without burning in. I also built a 6A current regulated driver to try out with this light but it somehow only pulled 4.7A L. In conclusion, with all my attempts Direct Drive with good current flow path is still the way to beef up the S12! I also want to mention that by now I have modded more than 8 S12 and only 3 had Pure White tint. The other five has a greenish/yellish tint. The LED in this S12 for sale does have the ideal Pure White Tint. If you want massive output and runtime I think you will happy with the modded S12. The only reason I am selling it is because I have an identical mod but with a copper head ;-).
$90 $99 $110 $115 Custom 3D/4C Magliet modded by me. For this project I molded molten solder into the flashlight head/neck to create the heatsink. This method allow a large chunk of solder to form perfectly into the body of the flashlight for good heat transfer. I then mounted an XML-U2 Pure White Tint onto the heat sink with Arctic silver thermal adhesive. For light focusing I used a very large and deep smooth aluminum reflector that is 55mm wide and about 60mm deep. To drive the LED I added a 2 mode 4.2A current regulated driver that can take 2.8V-6V so the light can run on 3D or 4C. The result in possibly the BEST THROWING reflector maglite with a typical maglite head size. That’s right! It throws better than my 11A Varapower 2000 SST-90. The beam is beautiful too! The bodyand bezel is new. The tail cap is mint. The head only has a slight scratch on it. If you are a perfectionist I guess you can change the head too.
SOLD $79 $85 $90 Brand New Deerelight DBS V3 modded with one of my XML-U2 4.2A 3 mode pill. Took me a while to perfectly adjust the LED height from the reflector to focus a tight hotspot with almost no donut hole. This light of course throws much better than a TN11 or Scorpion V2. If you like a pocket massive output thrower this light is for you. The light has a smooth reflector with a very beautiful beam.
SOLD $53 $60 $65 Modded TK35 Clone. 3 mode current regulated driver with memory. 2.8A max. 6 V max. Battery carrier modded to take single 18650, two 18650 in parallel or 4 CR123 is 2 serie 2 parallel configuration. 2.75V low voltage flicker. XML-U2 Cool white LED swapped! Pure white tint! THROWS like crazy!
SOLD $34 $35 $40 Modded Trustfire T2. Side clicky. Stainless steel head and tail buff with sand paper for beautiful even look. 1.4A 3 mode current regulated Low-Medium-High driver with memory. Lens diffused for beautiful floody beam. Excellent battery life. Great condition!
$169 $185 $195 $200 Unique Varapower 2000. SST-90 with variable brightness control ring. 6500K 100% cool white LED. Insanely bright! Brand New Reflector, head, and tail cap installed. GREAT condition! Batteries included. Can run on 3D or 4C. C size battery sleeve included.
$33 $34 $35 $39 Trustfire T1 XML-U2 LED swapped. Single mode Driver swap with 3-18V range. 2.5A. GREAT condition. Beautiful beam and really throws.
$33 $34 $35 $39 VB-16 with XML-U2 LED swapped. Low-High-Strobe 2*18650 light. Great condition! Beautiful super wide beam.
Paypal gift or +4% please
Paypal email: [email protected]
Re: REDUCED 2X vinhnguyen54 Random Modded Lights
I will take the Maelstrom S12. I am interested in one of your P60 thrower drop ins from your other thread as well, so I will send PP for both.
Paypal sent for:
1. Maelstrom S12 $135
2. EZ900 XRE-R2, SMOOTH reflector, 1.8A Single Mode 3-13V Max $38
Plus 4% = $179.92.
You can mail them both together once the drop-ins are completed. Thanks!
Fund recieved. I will ship the S12 first. I will ship the EZ900 as soon as I received the LED from Cutter for the build. Thanks!
I would like to take this - how much for international shipping to the UK.
PM sent
Thanks
Mohan
Paypal Payment Sent*(Unique Transaction ID #3812710716343545M). $84 net
Thanks
Mohan
I'll take the Modded Trustfire T2. Side clicky.
Exactly how much I should send via PayPal shipped to USA?
Thanks,
Tanasit
email sent regarding TK35 clone. thanks
nice collection. i wish i was here earlier... i would love a DBS
If the trustfire t1 single mode 2.5 amp U2 is still available I will take it for $33 + £5 shipping to UK $38, thanks
I will ping you a PM to.
Status
