Firstly don't chop off the regulation circuitry, it's better described as protection circuitry
No, it's actually regulation circuitry.
There are cells that are just protected and not regulated, but the RCR2s from DealExtreme are not that type.
Their regulator might include protection too, but its main purpose is to drop the voltage from 3.6/4.2 volts to 3.2/3.6. Which is precisely what I
don't want, so it has to go.
You're average phone or prismatic battery will have over/under voltage protection. You charge it with too high a voltage and the protection circuitry will cut off the power to the lion cell. You discharge the battery too low, and it will again cut off power to the application. Same with over/under current, over/under temperature.
This is all very important. Too much voltage/current in or out and the battery will catch fire. Charge it at too high a temp and it will catch fire, to low a temp and it will be damaged. Too much discharge and the chemical structure of the battery will be damaged, it will either fail and not work again, or it's life will be reduced
I am familiar with the workings of lithium cells, and I know the potential risks I take by running unprotected cells.
Charging is not a problem, as I have a dedicated LiIon charger that knows when to stop to avoid barbecuing the cells.
Deep discharge shouldn't be a problem either, because the LEDs I'll be running will probably be so dim by the time the cell reaches its lowest safe voltage I'll want to recharge it much sooner.
Let's just hope I manage to avoid shorting it while building the thing...
Also if you want to sell your application commercially, you'll be up against some regulations.
Nah. The first one I make (provided it all goes ok) will be for my use.
I might consider making others if I see the prototype comes out right, but I'd only ever sell them on eBay as homemade with no warranty whatsoever.
I know RC people use raw lion cells, but they invariably take special precautions like having a charging dish to take care of any problems, and usually don't stick their RC model down their pants pockets
Being a RC person myself, I have a deep respect for bare lithium-polymer cells... especially since a pack puffed up on me for no apparent reason just the other day, argh!
Having said that you can get small prismatic/cylinder units from places like sparkfun
Thanks for that, I didn't know sparkfun. Their shipping is quite cheap for small items, I'll probably be buying some stuff from them in the near future.
DM51: thanks, but I've no idea where to get them from. Google isn't helping either...
