milkyspit
[ QUOTE ]
Doug S said:
[ QUOTE ]
milkyspit said:
Does the use of a resistor in an unregulated LED flashlight such as the Streamlight 4AA LED reduce its power efficiency due to some of the energy being lost in the resistor as heat? I'm afraid I switched out of my Electrical Engineering major halfway through college, and now questions like this haunt me. /ubbthreads/images/graemlins/icon23.gif
[/ QUOTE ]
OK, actually answering the question you asked:
Yes, the resistor consumes power but in the case you cite, the more power the resistor consumes [relative to the LEDs, not necessarily in absolute terms], the *more* efficient the light becomes! It may not be as bright but it is more efficient in terms of light output per input of power. The reason for this is that the LEDs become more efficient as the current is reduced. If you wanted the highest possible lumen-hours per set of batteries the resistor would need to be high enough in value that the 5mm LEDs in the Streamlight were getting only a couple of mA each.
[/ QUOTE ]
THANK YOU Doug! This is exactly the type of insight I was hoping for! /ubbthreads/images/graemlins/thumbsup.gif
(Not to take anything away from the others who've contributed... I've enjoyed reading the thread as it's progressed, and have learned quite a bit. Thanks to all! /ubbthreads/images/graemlins/smile.gif )
I have a little bag o' Nichia 5mm LEDs (the super bright, 9200mcd ones I think) that I bought via eBay. Over the weekend I breadboarded a few of these in parallel, all fed by a 6V source consisting of four alkaline AA batt's limited by a 45 Ohm resistor. (In other words, the single resistor is between the positive voltage feed and the three paralleled LEDs.) I read a *total* current of approx. 65mA in the circuit with fresh batteries, and the leads of the LEDs didn't get warm at all, at least based on feeling them with my thumb and forefinger. Seems to me this circuit, encapsulated in a flashlight, would yield some nice runtimes? Or would I be better served to regulate via a BB? My goal is to drive the LEDs near full brightness, but using not a drop more power than necessary to do so! and keep running approximately this way for many many many hours...
I want this to be my designated "power failure light" that will be just bright enough to light a room, yet keep running for at least 20 hours, preferably at least several days...
Doug S said:
[ QUOTE ]
[/ QUOTE ]
[/ QUOTE ]
