constipated
- Joined
- Nov 7, 2009
- Messages
- 9
I have two AA eneloops that I've been using in an LED torch for about 2 years. It is of the high power variety and can probably drain them in 75-90 minutes although I don't use them continuously often. Once the torch starts to dim often they are completely flat. I don't know if there may have been some reverse charging involved. They are often kept in my car which in summer can easily get to over 40C / 105F during the day.
I have a Maha C9000 charger and on a recent break-in to tune them up. One battery was still around 1920mAH, but the other was about 1800mAH. I am a bit worried about further use causing more reverse charging near the end of the lower capacity cell's life.
What is the optimal way to try and bring back the extra 150mAH capacity. I thought eneloops were a bit better at resisting degradation.
Do repeated break-in cycles really work. I would like some real life accounts before I try this as they are so time consuming.
