ROP 2C Help!!
bouncer
I have a 2C ROP. I had an accident and dropped it and broke the bulb. I replaced it and now I cannot focus it like I could before. I used to be able to get a nice beam on my wall with no donut hole. Now no matter how I focus I can't get that tight beam. What am I doing wrong?
Is the bulb mounted straight in the holder? I'm assuming you are using a cammed reflector; was the cam damaged by the fall? Is the bulb holder able to move freely?
Sent from my DROID RAZR using Tapatalk 2
Thanks for the replies I'll try. If I take the head off and just put the reflector in it will get the focus right.
I tweaked the head and reflector and figured it out thanks for the help.
You got some good advice! You could also try another bulb. If you touched the bulb with your fingers, wipe it off with alcohol.
