Run-Time Plot - MagmaLED-AAA
Status
Not open for further replies.
Roy
Farewell our Curmudgeon Administrator
Granbury, Tx USA
This runtime plot is for an AAA Minimag with a Technology Associates MagmaLED drop-in modification. This single led conversion of an AAA Minimag was designed and intended to be put in a AA Minimag! At the end of 21 hours it was still generating enough light to see your feet with.
Equipment used is a photocell and a Radio Shack 22-805 multimeter with a PC interface that is using ScopeView software (V 1.08).
The vertical axis is in MA and the horzontal axis is 30 minutes per division.
Be aware that your actual battery mileage may vary from that indicated by this runtime plot.
To make this "pill" work in a AAA Minimag, two things may need to be done.
First, smooth the edges of the "pill" to insure that it does not stick in the head of the AAA minimag.
Second, it may be necessary to sand some of the bottom of the reflector off to obtain a tight focus.
I don't have a light meter, but in the AAA Minimag, the MagmaLED seems to put out more light than an ARC AAA.
ADDED:
A bit of WriteRight helps smooth the light pattern also!
Roy, thanks for the chart. I was just looking at those and wondering if I should get one for a minimag I have that is gathering dust. Do you think that it is a good mod for the $ or should I look else where? Any other CPFers with an opinion on the matter? I was hoping to modify a minimag and give it to my brother for EDC in his notebook computer case. Any feedback is appreciated as I am still learning about all the mods out there.
Which Minimag are you refering to? the 2xAA Minimag or the 2xAAA Minimag. To my knowledge, the MagmaLED conversion is the only one that will fit in the 2xAAA minimag.
Roy, thanks for pointing that out. I have the 2 AA that I want to mod first, then I would consider a mod for the 2 AAA. So, if the techass.com magmaLED is for the 2 AAA only, what should I look for to mod the 2 AA minimag?
Roy, Ditto the "thanks" of everyone else. Based on your chart I went ahead and orderd one to try in one of my "lonely" AAAs. I look forward to "using" it!
Roy, just saw the other thread on the 2xAA magmaLED as well - my bad...
Still interested in your opinions though, thanks.
The MagmaLED is the only minimag LED conversion unit that actually uses the reflector for focusing. Warning: do NOT use with Lithium AAs, as it will overheat very quickly.
You have 2 chances to get the polarity right and should get it on third or fourth try.
Charles,
Thanks for the tip on the lithiums. I was just about to put lithiums in my AA conversion. Are lithiums okay in the NewBeam conversion?
Here is my second attempt at beam shots! The light was about 10 inches from the target and the tic marks are at 1 inch.
The beam pattern has been smoothed by some WriteRight on the lens of the flashlight.
Status
