Sold/Expired sale over
Re: WTS: MillerMods Fenix L2P's, Nekomane RCR123A/CR123A bodies & accessories
pm sent! :grin2:
#1 and #3 sold to TwoWheelNomad
:paypal:
ID #6GL54118JR1472110
:thanks:
2 & 4 still available.
I think you have a misprint in #4: If i recall RCR won't fit, only primary.
I was iffy myself when I got them, thinking they were all CR123A bodies. But two of them really are RCR123A bodies. They are slightly thinner than the CR123A body. And protected AW RCR123A's do fit in these two, I verified this.
Apparently Nekomane did a special run of these.
The CR123A is best if you carry with a primary, because the body is stronger and there is no rattle. It's good to have both to switch back and forth depending on the situation.
Free bump!
The Nekomane bodies with unanodized threads on one side will also fit the original versions of the 2 level L2T and L2S. I wish I could get the pill out of mine to mod it with a P4.
None of the Fenix's were designed for 3.7v (4.2v max) LiIon so use at your own risk.
Free bump!
Which do you have? The Millermods version are not loctited, so the pill unscrews right out without any effort. I did unscrew one from and L2T once. It was not as hard as I thought it would be.
I couldn't find anything in the millermods section on the Fenixes, nor have I been around long enough to know, so I'll try here. What was done to mod these lights?
Millermods modded them with his high current driver. Fenix-store sold these originally.
Nekomane CR123A body is sold.
#2, 4a., 4b., & 4d. still available.
I'll take #2, PM Sent.
