I have a Samsung Galaxy Tab Active Pro SM-T547U tablet in a Ram Mount Tough-Case for Tab Active Pro. It has a power cord with a USB-A connector. My wife and I used it yesterday in our Can Am Maverick running the Polaris Ride Command Android app. In the Maverick 12 volt power outlet I have a Scosche dual USB car charger. The car charger is marked on the side:
Input: 10-16VDC 2.9 A
Output: 2.4A Per USB Port
When we used it yesterday the Samsung tablet showed that it was charging, but the charging never kept up. In other words, even though it showed it was charging, the battery percentage dropped during the ride.
I am now trying to determine what is causing it and how to proceed. It is possible that the Can Am is giving less than 2.9 amps at the power outlet that the Scosche needs. I suppose that can be measured with a multimeter.
The next possibility is that the Scosche dual USB car charger isn't really putting out the 2.4 amps that is claims. Can that also be checked with a multimeter?
I now want to try a different car charger that has at least one USB-A that puts out enough power to charge the Samsung and keep it at 100% battery.
I do recall reading that 18 watts per per is the maximum that a USB-A port can deliver.
I am considering a Ram GDS Type-C and Type A 2-Port Cigarette Charger, Samsung Adaptive Fast Charging Vehicle Charger or an Anker PowerDrive Speed+ 2 Car Charger. From the looks of it, any of them should work equally well. Any other considerations that I should be aware of?
www.samsung.com
rammount.com
rammount.com
Adaptive Fast Charging Vehicle Charger (Detachable Micro USB USB Cable) Mobile Accessories - EP-LN915UBESTA | Samsung US
Discover the latest features and innovations available in the Adaptive Fast Charging Vehicle Charger (Detachable Micro USB USB Cable).
GDS® Type-C and Type A 2-Port Cigarette Charger
This two-port GDS® USB Type-C and USB Type-A cigarette charger (RAM-GDS-CHARGE-PPS-CIGC) allows for charging two devices simultaneously. The USB Type-A port takes advantage of Qualcomm® Quick Charge™ 3.0 for compatible devices. With the USB Type-C port, utilize full 30W power delivery. To...
RAM® Tough-Case™ for Tab Active Pro and Active4 Pro – Type-C Male USB
This RAM® Tough-Case™ (RAM-TC-SAM54CU) is a rugged two-piece enclosure that supports No Battery Mode for the Samsung Galaxy Tab Active4 Pro by utilizing a built-in coiled USB Type-C power cable that tethers the device to a charging port inside the cab of any vehicle. This case allows you to...
