I've previously used power leds that are attached to PCB's, so electrical isolation of the led slug has not been an issue. Now I'm intrested of these Samsung "Sunnix5" 3 watt emitters without PCB:
http://www.led1.de/shop/product_inf...n-slhnnwh531t0-p-1076&cName=samsung-led-c-227
If I have got it right, when using bare emitters, slugs should be electrically isolated from the actual heatsink, especially when multiple emitters are used, correct?
But then I happened to read this Samsung manual about Sunnix:
http://samsung.led1.de/images/stories/file/datasheets/sunnix5/SLHNNWH531TO.pdf
..and there was a remark that: "Make sure the heatsink is electrically connected to the anode". Is this an error or have I just misunderstood something..?:thinking:
For example let's say that I'm using several of those Sunnix5 emitters connected in serial circuit and they are using the same heatsink. How should I do the slug/heatsink connection/isolation?
