Hello,
After reading about Sanyo Eneloops at this forum, I bought 4 of the new '1500' Eneloops last December to be used with my camera (Sony DSC W1). The charger I have is a Sony BC CS2B that was included with the camera. I have read the article here about that charger as well and learnt that it was OK for the Eneloops. When the first two batteries had been used up and required to be recharged, I calculated the time needed as 5 hours (2000mAh divided by 400mAh output of the charger). Therefore I removed the batteries from the charger after 5 hours (before the indicator light went out). Then I started using the other set of batteries. After they got depleted (about two months after) I put the first set into my camera but they show a low level of charge! What's strange is that after I charged them (and before storing them) they showed a "full" bar. The batteries were slightly warm (not burning hot) when they were being charged. I don't want to ruin these batteries because I've ruined two pairs of rechargeable NiMH batteries that were used with my camera! (I think the camera's jinxed:devil:).
The output of this charger is 400mAh, I've read that the ideal rate for Eneloops is 100mAh-200mAh. So should I change my charger?
Any reply is appreciated!
Regards.
Regards.
