Sanyo thinks Eneloops are ideal for flashlights?
I can definitely give them a big thumbs up for flashlights, cameras, and external camera flashguns - I use them in all of the above :D (got a set in my Canon 430EX right now)
I'm phasing out all my legacy NiMH in favor of the Eneloops as the opportunities come up.
Hello LowTEC,
The Eneloop cells may not be as good as normal NiMh cells in higher temperatures, and when the cell is in constant use. Higher capacity wins in these conditions.
Tom
I have a question as a battery newbie:
I am collecting the parts for a M@g85 and would like the LSD features of Eneloops or similar cells.
Are these suitable for the high drain of an 1185 bulb in a FiveMega 9AA - 3D adapter?
Any help would be appreciated.
Thanks,
HAK
Alteran said:
What is it about Eneloops and other LSD cells that are worse in these situations?
So far, AA size LSDs tend to have capacities around 2100 mah, compared to "normal" NiMH capacities of over 2500 mah.
AFAIK though, Eneloop and probably other LSDs hold their capacity better at very low temps better than normal NiMHs.
Hello Alteran,
There is some speculation, but no proof - so far, that the self discharge rate for low self discharge cells may end up higher than that for normal NiMh cells at higher temperatures. Higher temperatures are ambient temperatures above 86 F.
In constant use, the battery does not sit long enough for the self discharge rate to be an issue.
Tom
