SBT90 or SBT70 which is better thrower?
Fresh Light
Stratford WI
I'm curious what you think will be the better thrower. Please notice the tint of the 90 is 6500k and the 70 is 7000k.
Digikey has a MB flux bin SBT90 1485-1590 [email protected] it is $78.95
Mouser has a SBT70 1710 [email protected] it is $39.00
I know the increase in flux with increase in current isn't linear, but 1590* 117%(amt of rated current of the SBT70 vs SBT90)= 1855. If I take 1855, actually with droop it will be less, and multiply that by 0.778(difference in mm sq to the smaller SBT70)= 1443 lumens. 1443 lumens is a lot less than the SBT70s 1710, 15.6% less. So, if that makes any sense, it sounds like the SBT70 may be a pretty bright LED. I don't know which is better. 39.00 vs 79.00 is a significant difference, but considering the cost of the lights and how important the LED is I would want whatever is better.
Can you link to the SBT-70? I am looking for that since the paper release :)
Edit: Those sites s**k (mouser and avnet), filtering through the parts I am not able to find them. But the search does, and lots of them. They are put in the "HB led" section, where all the SST-90 and SST-50 variants are, not the CBT-90 etc.
Avnet (hope this works, but it's worth the try):
https://avnetexpress.avnet.com/stor...m=sbt70&N=0&Ne=100000&action=products&x=0&y=0
No stock and data yet
Mouser (this will probably work):
http://www2.mouser.com/Search/Refine.aspx?Keyword=sbt70
stock and prices.
Datasheet:
http://www.mouser.com/catalog/specsheets/PDS-002014_Rev 0X_SBT-70 Production Specification.pdf
up to ~1650lumen for cool white
up to ~1350lumen for 90CRI
up to ~ 900lumen for 95CRI
I honestly don't know if it's ok to post links to selling sites even after going through the Rules. Sometimes it's ok but if it's a Dx or Kd link, it is removed. I've found posted links to be helpful. I'll PM you.
I know we aren't supposed to post dealer links in the recommendation forum, but outside that forum I get the feeling that it's ok, as long as they aren't advertisements and aren't overdone. Could a mod please correct me if I'm wrong?
I can't imagine there'll be any issues as you're discussing components, not actual flashlights.
You're not spruiking a product, you're being helpful.
Now, as for which LED would be a better thrower, I got 170-190 lumen/mm for the 90 CRI cool white, and 190-240 lumen/mm for the 70 CRI cool white with the SBT-70 @ 10.5 A rated current (higher bin = higher lumen/mm of course). 140-175 lumen/mm for the 70 CRI white SBT 90 @ 9 A. Assuming both LEDs are driven at the max current, the SBT-70 would throw further.
Numbers are estimates from the datasheet. Actual lumen/mm is probably higher due to my truncation of numbers, and after subtracting the current spreader areas. A good heatsink ant thermal path would help hold the output level of course.
