Wylie
I am looking for a cop out so I think you guys hooked me on this thing with the leds.
I was up again early into the morning this morning toying with some 6000 mcd white leds I had hanging around. I took a little file and filed off the bases on three of them, then I took an o-ring and used it like a rubber band and wrapped them together nice and neat. Next I used a sewing needle and very carefully dropped some 6000 psi fast curing epoxy in the middle of them and around the outer edges to hold them together. Keeping the cathodes to the inner area of my cluster I bent them inward and soldered a 1/4 watt 10 ohm resistor in the middle of the cathodes after they were cut to the right length. Okay it may be a little over driven.
I added a little ball of solder for a conductor after cutting the lead on the resistor and this slipped through the little plastic conductor holder I made a larger hole in just like it was a factor application. I took a small scrap of wire and made ring around the anodes and left a tag end for grounding. This is were things got a little tricky as the cluster of leds was too large to fit into the battery cylinder of the two AAA knock offs I had pressed together into a brass cylinder to make a three cell AAA battery cylinder. The cluster was just small enough I got the lens housing to fit over it after removing the lens and reflector but I had to install it very carefully.
After a little tricky fitting and a little more epoxy to keep the conductors separated I had a three led three AAA cell flashlight that rocks. I think I should stop pointing my new toys directly into my eyes.
I don’t know why I do it but I am dotting my eyes with my new toys all the time now. This is the brightest little flashlight I have made yet and I am only using old batteries at this time. If any of you would be interested, I will set up some pictures for you but the best I can do at this point would be exterior pictures as I do not want to take this one apart because I may not sure I would be able to get it back together. Six more leds and enough parts to make two more and I think I am going for it.
Mag Instruments has got nothing on this little number.
Keeping it real, bright
Wylie
Wylie
