TigerhawkT3
That's pretty weird with the preemptive quote.
I've seen MagLED products at Wal*Mart, Home Depot, and Fry's.
This is a high-quality variation of the light I recommended. It can be had, including 18650s and charger, for $100 or less.nerdgineer said:Waion's new VB-16 lets you set power levels from 0.3 through 4 watts (plus a moon mode) and runs off rechargeable 18650's and 2xRCR123s (also primary cells). Beam does have a hot spot but the smallish reflector gives a brighter spill compared to the hot spot. It has type 3 hard anodization, coated glass lens, etc. and costs $55 shipped.
Don't know run times but if it ran 2 hrs to 50% at full power (level 32) on one 18650 (an educated guess), it should (assuming equal efficiency at all levels) deliver 50 hours at level 2. Level one is a moon mode which I guesstimate would deliver about 2000 hours run time on one charged 18650.
I don't recall if the MagLED package said NO RECHARGEABLE or not. I use rechargeables with it and so far, no troubles.LEDninja said:I have Press n Seal under the lens of my MagLED 2C. I can focus to a pretty wide flood with no donut hole. The instructions on my drop-in clearly state NO RCHARGEABLE BATTERIES.
