SF 6P twisty and 3 stage drop in LED module..how to use it?...help
marinemaster
Atlanta, GA
Hi,
I did see this topic before, but I cant find it.
So I have a SF 6P with a twisty switch. Now I want to use a 3 stage low/med/high LED drop in. Will it work? How do I use it?
Forget about clicky for now, twisty only.
Chris
Assuming ur using the typical kind of multimode drop in, you just have to turn it on and off within a second to make it change the modes.
Doesn't matter weather its a clicky or a twisty, works the same.
