SF A2 LED Assembly Problem
FlashlightOCD
Central FL, USA
I recently removed and re-installed the LED assembly in my A2 [I was wanting to swap LED colours with someone]. I have noticed since doing this that one of the three LEDs will intermittently go off, most noticable after the high beam has been active for several seconds. Has anybody else seen this behaviour? Any ideas what the problem might be?
I'm not sure if it was doing this before the remove/reinstall because I wasn't really checking for it.
TIA for any suggestions.
It could be a crack in the soldering. /ubbthreads/images/graemlins/rolleyes.gif You might want to touch up the solder joints, but make sure you don't overheat... /ubbthreads/images/graemlins/mad.gif /ubbthreads/images/graemlins/crazy.gif
Aslo try to tighten the LED assembly screws, I noticed on mine when I exchanged the assembly that all the LEDs didnt light up until all the screws were tightened.
Bjorn
