mowermechanic
- Joined
- Oct 13, 2011
- Messages
- 6
To hold me over untill I decide to start my mod, I'm buying a pack of RCR123's with a charger. I first was looking to install a medium output malkoff dropin (M61L). It's 3 times brigher than my incan. bulb, also will last up to 5 times longer on standard batteries. The Malkoff dropin can take up to 9 volts which means I could install 2 3.6v RCR123 cells instead of 3.0v. Then I discovered the 18350 is almost identical in demensions but has superior MAH and 2 3.7v batteries would be 8.4v which is still under my 9v ceiling. Has anyone fit 18350's in a G2 or similar light? it's only 1mm wider and .5mm longer so i'm thinking with a little honing maybe?
