[ QUOTE ]
Size15's said:
The A19 is used to extend the body to house an additional SF123A. The A19 is a black anodised metal component.
This is a G2+A19:
It holds three-SF123As and uses the P90/P91 Lamp Assemblies.
Notice I'm using the G2Z Bezel with it's Pyrex lens (because the three-SF123A models get rather hot - Especially in Nitrolon rather than Aluminium.
The A14/AN14 is used to extend the body to house the B65 NiCad Battery Stick.
The G2 and G2R use the P60 Lamp Assembly
You can swap between rechargeable and SF123As if you have the Z29 Battery Spacer:
Al
[/ QUOTE ]
Hi Al,
Confused newbie here. First you mention using the P90 with three 123s with the result that it gets rather hot. Then you mention using the P60 with three 123s. Is the excessive heat due to the three 123s plus the P90, or will a P60 also get too hot with 3 123s?
Let's see if I also have the other parts down:
-The A14 and A19 are metallic and match the 6P
-The AN14 is nitrolon and matches the G2
-There is no AN19
-The A14 and AN14 are longer and accomodate the B65
-Each A19 adds one 123.
I don't see any A19s on the Surefire site or on several other sites.
Thanks,
Bill D.
