Thank you for your answers! I have made some more measurements.
First some more info of my setup:
The shark is cooled by a copper plate from the backside of the board.
I have the shark connected to 5V from a PC powersupply (max 16A). I have put a 100uF capacitor with low impedance on the input, close to the shark.
On the output 2 leds in series. Vf=6,6V@0,55A.
I measure I-in, I-out and V-out simultaneously.
When I turn the pot from low to high, the output current first increases relatively linear up to 0,45A, then It starts to flatten out to 0,56A
The input current continues to rise though, and is 3A when pot fully turned.
The Shark eats all extra power fed to the board. Fortunately the heatsink works well.
I find this behaviour strange.
I have measured the resistance of the pot and it is 18.9k.
I also put the board on top of a flashlight to see if any of the tracks were broken, or components missing.
I'm not willing to test the components on the board individually, as they are so hard to solder with the iron. Even if I use my smallest tip...
