single primary cell current controlled XM-L?
js82
Hi,
Are there any good flashlights that have the following specs?
-XM-L emitter, preferably neutral
-single primary cell (CR123A, AA, AAA)
-current controlled on all constant output modes
-super floody
-has very low output mode (moonlight mode)
-has high output mode with a minimum of 200 OTF lumens
-has medium mode
-has beacon or SOS, and strobe
-IPX8 or better
-has interface that doesn't require going through higher modes before getting to lower modes, and also doesn't require going through strobe to get to non-flashing output modes
I'd like an EDC like this, whether in SS or hard-anodized aluminum.
The only fashlight i know that at least fits many of your requirement ist the quark miniX 123:
http://www.4sevens.com/product_info.php?cPath=297_429&products_id=2564
-XM-L emitter, preferably neutral <-Ok
-single primary cell (CR123A, AA, AAA) <-Ok
-current controlled on all constant output modes <-??
-super floody <-??
-has very low output mode (moonlight mode) <-Ok
-has high output mode with a minimum of 200 OTF lumens <-Ok
-has medium mode <-Ok
-has beacon or SOS, and strobe <-Ok
-IPX8 or better <-Ok
-has interface that doesn't require going through higher modes before getting to lower modes, and also doesn't require going through strobe to get to non-flashing output modes <-Ok
-super floody <-??
It's PWM controlled unfortunately, just like the thrunite neutron. Anything else?
