Single RCR123 light
onthelake
Sorry gang, I have been away from this forum for quite some time. I am in need of a single CR123 light that is a mix between flood and throw to take the dogs out at night. Specs below:
Throw distance 100m
Flood spread to light up all around: 25M
Lumen: 400+ down <=1 lumen (adjustable) Price= under $900
I just lost my Dataled HDS U60 with 600+lumen that I loved. Any help to replace her would be much appreciated.
I feel like such a noob asking here, but am upset that I lost my favorite light right now and don't have the patience to find the latest and greatest....
Throwers; I have those. All floods, I have those too. I am looking for the best in the rcr123 form factor that is readily available.
Cheers,
OnTheLake
Quark QP2L-X Burst Mode on a 1xCR123 tube, running an IMR 16340 for ~750 max (1 min stepdown) and 0.5 lm moonlight. Has a nice single-handed momentary max "feature"/(work around) from any lower mode in use that I find ideal for dog walking. Spot the Dog off leash at a distance, fire two quick flashes at approaching cars to signal them pedestrians are ahead, check that bump in the woods - returns to previously used low mode upon release.
I haven't had much luck with anything 4seven. They seem to only last a short time. Either the diode over heats and get fried, or the electronic ui gets messed up and renders the light useless or I just accidental drop the light and it stops working.
I am quite rough on my flashlights. They are mere tools to me. I haven't any shelf queens, though many other people would baby the lights that I have.
I put the dollar amount at under 900 as this search should yield custom lights, but not any spy 00*'s. I just looking for the latest and greatest that is also bombproof.
If you liked the HDS before, why not get another? A Clicky or Rotary, although if you're rough on it, a Clicky is probably better. They have caught up on their backlog. You'll have to have someone customize it to get more than the 200-250 lumens they put out as standard, but with that budget, it should be possible.
