ksbman
I received my Argo from Bright Guy Thursday after ordering it Wednesday. Very fast!
I took it to work with me last night to see how well it would do against the SL Septor I currently am using.
The Argo uses a one watt side emitter and the reflector is textured only on the lower half. Shinning it on a wall from a foot away produces a very ugly pattern but in real usage that is not noticeable.
The tint is nice and white and compared next to the Septor it makes the Septor look very blue.
The middle setting on the Argo looks about as bright as the high setting on the Septor. That's good because the high setting on the Argo is only good for an hour’s runtime.
Now for the bad news.
I used the Argo on high for about 20 minutes last night then switched down to medium for about another 15 minutes. After that 15 the light went out.
I fiddled with it, trying to get it back on but it would not stay on, just kept going out after a few seconds. When the light would come on the middle power indicator light would be on. After two seconds the low power light would come on then the light would go out.
I replaced the batteries and it worked again.
After using it for another half-hour or so on the medium setting the light again went out. Again the power indicators showed the batteries were drained.
I called Greg at Bright Guy this morning and he's going to do a runtime test on one of the Argos he has there. If it works fine he'll replace mine. If it does the same thing he'll refund my money and Stream Light has a problem with their Argos.
I'll update this when I hear from Greg
