SL TL-2 LED...Impressions
The post does appear to be plastic with a shrink wrap boot around it, but the real question is "what is the plastic part of the post surrounding?" Is it solid plastic, or is there a shaft of aluminum in the center attached to the base of the emitter? Hence why I mentioned "dissection"... /ubbthreads/images/graemlins/smile.gif
[ QUOTE ]
Y2Kirk1028 said:
Perhaps this might help.
[/ QUOTE ]
Kirk, why yes it does! Am I interpreting your photos correctly that it is a semi-destructive operation to access the stock resistor board? Also, is that stepped alumimun plug of the lamp assembly a fairly snug fit into the battery tube?
my 2 cents worth on a gently pre-owned TL-2 I just got--pretty much an echo of PJD and JohnK--very impressive light/$
very white, very uniform and intense center for a 1W (my Q3J in a M*g 2D has a brighter center spot, but smaller--obviously not a fair comparison, reflectorwise and the exceptional mini-LGI is comparable, but has the gradual falloff of an optic 1W and is not as white)
fells very good in the hand and the switch does not require a simian thumb to actuate
looking at jcciv's excellent pics looks like they didn't go the extra mile, but since it's a production light that don't totally shock me
hideo
