Mugrunty
- Joined
- Feb 12, 2007
- Messages
- 163
Hello,
I decided to post this information here instead of where it used to be in the POB Battery meter post. It was too off topic! I took a few screenshots of the programs I made for the TI-84 plus calculator. It can tell you the Estimated State of charge for your POB lead acid battery based on open circuit voltage. I also made a little program to estimate runtime on a 7Ah battery depending on the current draw. It compensates for the decreased capacity you get when you put large loads on Lead acid batteries. Take your POB for example. That unit draws about 3.6 ish amps after warming up IIRC. You punch that in your calculator... 7/3.6 and you get 1.94 hours. Obviously thats not what you get with your POB. Now, you use this extra cool formula and you would get 1.25 hrs (1hr 15min). Very close to the actual runtime of that flashlight! (~70min)
I'll post the formula that the program uses.
If current draw is < 1/20C or 350mA, just divide the numbers normally
If current draw is > 350mA, use the following formula:
RUNTIME (hrs) = 5.8488 * I(^-1.203)
Just plug your current into I.
The SOC formula is a really nasty polynomial equation so I wont post it unless someones really interested.
I got all this data from BB battery datasheets, me using excel to form equations and graphs, a pdf on Valve regulated batteries, and the David linden Handbook of batteries book. Here are some screenshots of the programs. Too bad I cannot host the programs somewhere.
:grin2:
:grin2:
