I finally completed my own little quad P4 after many hours of frustration... It isn't quite what I had planned (was planning triple stage) but I'm quite happy with it anyways. I just figured someone else might find this helpful so I thought I'd post what I did. This is by no means an original idea, the Orb uses a similar idea for the switch, but I don't think I've seen anyone do it with this type of mod.
I decided when I started that I wanted at least dual stage output on this light but I absolutely hate having an external pot or switch because I think they completely destroy the look of a light. I wanted to be able to switch between levels simply by rotating the head of the flashlight, so I made it happen using a reed switch and some resistors.
Enough jabbering, I think the pictures should be pretty self explanatory so here goes (sorry about the poor quality, I really need to get myself a macro lens):
The reed-switch-resistor-combo that does the switching. It's a normally open switch.
And here it is stuffed into the light held in place by simple hot glue which will be replaced by epoxy once I'm happy with the twisty action of it.
The magnet that activates the switch. It's simply glued down onto the switch housing on a spacer (a bit of antenna cable ). Took a couple of tries to get the distance and placement correct.
I guess that's about it, hope someone finds it useful
