Slightly OT - 5V regulator
KC2IXE
New York City
Hi Gang,
OK, I'm designing a non flashlight circuit, but need a 5 volt regulator - of course, the old classic would be a 7805, or a , or a LMx17 set to 5v (as I have a whole bin of them - 10/$1 at the last hamfest). Anyway, I happen to be in a spot where power dissipation is an issue, and I KNOW in some past thread here I saw some pretty much drop in replacement regulators that dissipate a LOT less current - if I remember right they were a "switcher in a chip", but I'll be darned if I can find them
I NEED an output of at LEAST 16mA output (which would leave me with ZERO safety factor - my relays are rated for 80mW draw) - the GOOD news is I should never be pulling more than 1 at a time - so say if I can get 50mA, I should be good
Anyone point me to the right chip? (Man, I miss having my bookshelf of databooks - for some reason, I always have MORE problems when I have to search on the web - don't ask me)
Supply voltage? In the 7-12 v nominal range, but call it 7-13.8 nominal range - most times, the end use will me 12v nominal, but there are some projects where I'd LIKE to go down to 7ish, and works would be "Car Battery" and all that implies (run away regulators when things fail, etc) - but the 90% case is regulated 12VDC
Well... there are DC/DC converters if you really don't want to deal with the inefficiencies of a linear regulator
http://www.mouser.com/ProductDetail...=sGAEpiMZZMtwaiKVUtQsNemMZL4TplJBqOl7845nWHA=
7-36Vin, +5V out 1.5A max...but likely you'll never need that high. 85% efficiency for about $4 before shipping.
It's alot cheaper than what dimension engineering gives, which I would only consider as a last resort
The MAX638 costs about $2.50/1000 (a quarter cent each), but I'm sure it will cost a bit more than that in single quantities.
Eh... I think that is $2.50 a piece when you buy 1000 pieces.
I have used similar components from Maxim, and I don't believe the price will come under a dollar, even in large quantities.
@ only 50 mA, and if your load tolerates chopped DC, you could use a 555 timer at some freq. and vary the duty cycle to get your desired avg. DC value.
