A
APKhaos
Guest
This board is impressive! Hope its OK to ask a non-flashlight LED question......
I'm working on a project to develop a LED replacement for the gauge lighting on older Porsche 911s. The stock incandescent lighting sucks, and there are lots of 911 DIY guys who are looking for something better. This is more a labor of love than a commercial project - it looks like the fabrication process will be daunting! For more details on the project, look here - http://forums.pelicanparts.com/showthread.php?s=&threadid=89372
The project needs a lot of light. Space is restricted to 9mm overall diameter for the LED assembly. The internal gauge lighting design relies on reflected light from the incandescent bulbs [1 or 2 per gauge].
I'm currently testing with 4 x 3mm LED arrays from superbrightleds.com, but I really need to fabricate the arrays myself to solve the dispersion problem. I can get four 3mm packages lying on their sides for better dispersal around the gauge, or maybe up to 6 x 3mm LEDs mounted verically in the available space.
Have also looked at the Luxeon emitters, but not sure the 1 watt version derated to 100mA [no heat sink] would be brighter than 4 or 6 x 3mm packages.
So...some dumb questions:
- What are the brightest 3mm LEDS to use? Beam dispersal is important if there are more than 4.
Need white, plus perhaps red as an optional color.
The Nichias seem to be highly rated - is there anything better?
- Which will deliver more light - an array of 4 or 6 x 3mm packages or a Luxeon 1W emitter derated to 100mA?
- This sounds agricultural, but it may be possible to mould form thermal epoxy around the emitter slug to bulb base to sink some heat via the bulb base to the gauge case. Is thermal epoxy mechanically strong enough to form a 9mm x 4mm slug which would bond the emitter to the 7mm base?
- Anybody have a reference design for a constant current supply w/ 12V to 14V input range, output current for 32 or 48 3mm LEDS, and dimmable?
Really appreciate any info.
Thanx,
Tony K
Thanx,
Tony K
