Slippers vs. sandals question?
wadecdesh
what is the difference between sandals and slippers? I recently bought a pair and on reaching home my brother asked by why I choose sandals rather then slippers. Both were made of rubber so I presumed they were slippers. Are their any other markers I can use to determine the difference?
Sandals are an ancient torture device used to pry your big toe away from your other toes to get the wearer to give up some information that the interrogators want.
I'd choose slippers because of the higher lumen output and the deeper reflector. But with sandals, you will have better run times using 18650 cells and the UI is easier to setup the different light levels.
Sent from my DROID RAZR MAXX using Tapatalk 2
With sandals, the rubber is perfect for impact protection.
Although if they are slippers, Be SURE to tighten them up. You don't need them to slip. :fail:
:D :D :D :D :D :D :D :D :D :D :D :D :D :D :D
