Ian2381
Is it safe to use Solar charger to charge eneloop AAs or does it have negative effects? i just bought a cheap solar charger and Im reluctant to use my eneloops. I also saw a solar panels with a AA holder to charge batteries.
The battery charger needs to run off low voltage DC power, such as a 12 V (car) or 5 V (USB) input. And it can't be intermittent, it must be continuous (unless you are doing a low current timed charge). That means your solar supply needs continuous sunlight, or it must have its own battery to store the sunlight, such as the one linked by pblanch.Just to clarify the posts here about putting a battery charger between the solar charger and the battery cell...
Would it have to be be a dumb battery charger? I can't imagine something like the LaCrosse would work well with intermittent wall power. And your solar panel setup would need some kind of rectifier to convert the power for 110 VAC wall power, right?
Is there an off the shielf solar panel/charging system like this. I wanted to use it when I go camping to charge up AA, cell phone, etc.
- solar panel(s) can be rolled up or folded so that it will take up a smaller area
- weather proof (at least dust proof I guess)
- able to deliver enough juice (Am?) to charge 2 to 4 AA NiMH in maybe 4-6 hours of sun light
- USB? regular plug?
Thanks
Look at the Cottonpickers Solar Powered & USB Chargers.
http://www.cpfmarketplace.com/mp/sh...Solar-Powered-amp-USB-Chargers-2-panels-added
Bump for further direction on a charger/Battery set up that could be used for eneloops on an extended wilderness expedition
