Hello,
I am designing a Solar outdoor light and I want your input on the design aspect. I realize you guys are expert in this field.
The outdoor light should be reliable and lives up to it's promise of meeting the following criteria:
It must run for 10 hours and maintain constant light output for at least 8 hours throughout the night.
LED:
I am going to use one cree MX-3 LEDs per light running at 0.68 watts/0.2Amps
for 10 hours that's 2000mah.
Battery:
I am trying to select a quality battery for the system that should last at least 2 years.
I found the Rayovac hybrid rechargeable 2000mah ( realistically I want more mah but that should do it for now). The manufacturer claims it can be recharged 1000 times. So that's 1000/365 =2.7 years. The question is does that 1000 times assuming your draining the battery all the way down or to a certain percentage from it's fully charged state?
Charging system:
I will have to you use a Nimh charging chip..that's work in progress
Solar power:
I selected a 3w monocrystalline panel. Assuming 6 hours of light and panel outputting half it's claimed wattage so 1.5 watts.
6hours x1.5 watts= 9 watts-hours
Does anyone you have a better recommendation for a battery system or LED selection?
Thank you
LED:
Battery:
Charging system:
Solar power:
Thank you
